Just tried “regular” oil in Sebenza, wow!
Peakbagger46
Cleaned out my only CRK (a well loved large 21 Insingo) today. I decided to try out some Benchmade blue lube instead of the usual florinated grease. Feels like a different knife, way smoother while still maintaining a hydraulic feel. Definitely less friction going on.
I’m thinking when the time comes again to wash it out (soap and hot water is my go-to with folders) I can skip the takedown and add fresh lube to the pivot if I’m feeling lazy.
Anyone else experiment with something other than the recommended grease?
I have tried various lubes but the CRK grease gives me the most consistent results without attracting grit to the pivot area.
I use either Lps or mineral oil in my small Sebenza. Lps is slightly better than mineral oil .
But if you are going to use your knife for food preparation. Use mineral oil as it is non toxic.
Just get a pint at drug store. For application use a oiler , like a titan precision oiler .
A drop,on each side of the bushing . Just stay off the lock bar .
For giggles, I put a drop of nano-oil on each side of the washer (small inkosi insingo, hasn't been taken a part for at least 6+ months and has been my EDC) and my experience is very similar to yours. I'm not sure how long it will last, but I like it.
Can a 1/4 a drop of oil really be all that toxic?
No :)
When Chris Reeve used to be on here, he said the grease was essential to the knife's design. It both lubricates and protects the pivot assembly from corrosion.
No :)
Grease is supposed to last longer than oil. In other words, it will keep your pivot lubed and protected for a longer time. Same thing with firearms.
Oils and other treatments like BreakFree/CLP work very well but you'd have to repeat the treatment at more regular intervals than grease.
