- Jun 16, 2010
Ok, so I'm not sure if this has been done yet or not. I took some waxed jute twine and I decided to add a little twist to it.
I first took a tea candle and removed the candle from the metal container. I then melted down some extra wax to pour back into the metal container and also to soak my jute in. I cute all strips into 6 inch sections for the rest of my fire starting kits, and cute one of those strips into 2 pieces to put one into the candle. You can youtube how to do this or look at the other thread on this. I constructed a makeshift holder to keep the jute upright during the cooling process to keep it from tipping over.
By intheshaw at 2011-10-08
From there you can see the finished cooled product. The jute twine is wrapped up inside of the tea candle slightly.
Now to test the performance between regular 3 inch waxed strip and the 3 inch strip inside the tea candle.
The jute caught on one spark from my steel and the fire last 21.9 seconds. Now I tested the 3 inch section inside of the tea candle.
It also caught on one strike.
This picture was taken at about 2 minutes of burning.
This picture just shows the size of the flames coming off the jute candle
At about 5 minutes, the candle wax had completely melted away but soaked into the existing ashes and continued to burn.
This picture is at 10 minutes as you can see. Its hard to tell but these is still a small flame burning and I put a piece of tinder in the flame and it caught.
At almost 12 and a half minutes the flame finally burned out. I placed some tinder on top and it barely charred the edges but if you tried hard, you could probably get it going.
So as far as I can tell, it's definitely worth the extra 10 minutes to make the jute candles. From start to finish it took approximately 30 minutes with most of that time coming from melting the wax on low heat. I had mad 30 6" jute strands and one candle. I tried to make 2 candles but didn't realize one had a pinhole and all the wax poured out. So with some quick math the jute candle last almost 35 times longer than the regular waxed jute.
I was surprised that it lasted as long as it did, and will definitely make more of the jute candles. I only made one for the test run but plan on making more. It would be worth the little bit of extra room that the tea candle takes up over a regular strand. There was also a slight wind during all of the testing. This was my first try at this and first review so I hope that you guys like this.
