JYD Composite: tip up lowrider?
Hello STR,
I was wondering how much a tip up conversion+ lowrider clip would run me. If someone could let me know that would be great.
Its all right here in my sticky thread http://www.bladeforums.com/forums/showthread.php?t=525771
Same cost to make one that screws in the factory holes but what I need to point out is this. If yours is the frame lock model anytime you have a frame lock with lock cuts on the outside its tricky to flip to tip up at times. It depends on how the lock cut was done where its thinned down. The JYDII, Volt, and others like that can snag and catch the rim of the pocket as you slide the knife on the pocket and as you try to pull it out. Its a very annoying thing on some and makes for flipping the clips a 50/50 kind of thing that can require tweak afte tweak on my part to get it right. At times the clip has to be positioned differently than you may want to put it just to make sure this is not a problem.
If your model has scales its no worry at all. I would need you to read and go over that link above and to click the link in the end to fill out and print my work order form. Thanks for asking
STR
Its not a problem to flip that for you. Just follow the instructions in that link and all you need to know is there to get it to me. Once here I'll do the rest and ship it home after alerting you that its all done and ready to head back. Thanks for asking.
STR
