www.bladeforums.com
Trying to remove the pommel on the k-bar 1207 but can’t figure out how to get pin out or even where the pin is I don’t see any pin
Is it like this one?
The pin will be about half way between the front face of the pommel and the "ridge".
Where the 10 and a 1/2 inch is on the rule above, or about 1/4 inch to 3/8 back from the front face as in the pic.
*There may be slight differences in this though as I think these may have been hand ground and not machine.*
It is a different pommel to the MK1/2,but same through pinning as the MK2, I can suggest the following:-
Breathe on the alloy pommel for a little while, sometimes it will show up as a circle of darker metal than the surrounds.
(I think eveled mentioned putting it in the freezer to get the same result.)
I have also had success with putting a drop of lemon juice on where the pin should be and let it sit for a while.
Let us know how you go with it.
Hope this helps.
