KA-BAR 22 Sharpening and Storage
Greetings all.
New to the forum and fixed blade knives. I just purchased the KA-Bar 22 and have a couple of questions. I did not see these questions addressed when I did a search.
Sharpening:
I own both the Spyderco Tri-Angle Sharpmaker and the Work Sharp Knife & Tool Sharpener (Original). Any issues with using either of these? If so, what might I consider?
I see from the knife spec that the angle is 20 degrees and the grind is flat. The Worksharp does have a 20 degree guide but seems only for thin blades. Seems also to push the convex grind.
Storage:
Is it really required to store knife in the paper sleeve that came with it, or can I simply leave it in the nylon sheath that came with the knife?
Hope to learn much on these forums.
Open to suggestions for sure.
You can use either to sharpen, many guys want to convex the bk2/ 22. Don't be afraid to drop the angle from 20° i love how mine performed at 17°.
Did this on the wicked edge to 18°.https://youtu.be/Z6tv4hSQfYE
I leave all my knives in the sheath...just keep it oiled as carbon steel will rust.
Sent from my SM-G935V using Tapatalk
Great. Thanks.
The 20 degree guide on the WorkSharp is only for the kitchen knives. Looks like I can get another one from them that accepts wider blades.
