Ka-Bar Grass Machete Impressions
Guyon
Biscuit Whisperer
Super Mod
Hybrid is the word that comes to mind when I use this knife.
As I was telling someone else earlier today, this knife strikes a very nice balance between chopper and machete.
It's not a brush cutter like a thin 18"+ Tramontina or similar machete. On the other hand, it's not a big 1/4" thick chopper either.
It is a sizeable knife though with a big honkin' 1085 carbon-steel blade. Specs online say 13 1/4" or 14" depending on where you look.
Mine measures in right at 13 3/4" long with a 1/8" thick blade. I didn't spec it with calipers, but just eyeballed against a tape measure.
I have mostly used my Grass Machete for wood processing, and in the pictures below, I am prepping a couple of evening fires in a fire bowl out back.
In this first fire, I batoned through a number of logs and stacked them, chimney-like, in the bowl.
The Grass Machete will make quick work of smaller limbs.
The knife features Tooj's very comfortable handles that I've come to like on both the Grass Machete and the Cutlass.
The knife handled lateral stress quite well. Here it is being torqued sideways by some whomper-jawed wood grain.
Beaten out of the log, the blade snapped back to straight just fine.
And after a little more beating, I did make it through the log.
The happy knife after a good work-out...
... and warming by the fireside.
Some conclusions:
It's a great, affordable knife that can pull double duty as chopper or machete. The steel has a good heat treatment and holds an edge.
I've put mine through its paces three or four times now, and the blade is still shaving sharp (literally...I just took some hair off my forearm with it).
If you need something for bush or tree clearing or for camp-side wood processing, this knife will serve you well, and though I prefer more reach and a thinner blade for clearing thinner media (vines, grass, etc.), this blade will still do the job at 1/8" thick.
Guyon, I really like how you've been doing lots of these "impressions." For those of us who haven't been able to handle as many blades, these are great little insights into the "personality" of the blades.
Question though. With all of these beastly wood processing knives you have... what do you end up using the most? I mean, I know you have a BK9, a cutlass, and a bunch of other large blades. Also, what do you find yourself using each blade for the most (of the ones you've done "impressions" of at least).
And great photos, I love the edge the grass machete has... the double bevel there is pretty cool looking.
I don't know if there's just "the one." I enjoy rotating blades out and appreciating their relative merits. Some of the other big ones that float my boat?
Becker BK-9, Becker BK-1, Becker BK-4, ESEE Junglas, Ka-Bar Cutlass, Busse SHBM, Busse NMFBM, Busse FBM SE '07, Swamp Rat Rat Mastiff, Swamp Rat Battle Rat, Siegle Jungle Knife.
Awesome photos and a great looker there. I'm really, really surprised at the kind of lumber you were throwing at that thing, and WFT with that bend!
Where's the balance? Seems like it'd have to be really far forward due to the blade length.
Anyway, nice looker and only about $50. Kind of hard to beat.
What did you think of the sheath. My biggest complaint about a lot of the new machetes and larger knives are the sheaths.
How does it chop compared to say, the KaBar Kuk, Cutlass Machete, and the Heavy Bowie (other blades in the same price category and with the same handle).
I kinda like the idea of a thicker machete, seeing how around here we don't have much in the way of grass or other leafy vegetation. Just like you said, it seems like this one is long enough to give some reach, but sturdy enough to beat on a bit.
Also, anything else in this same "in between" category? I'm not too familiar with machetes.
And thanks again for all these "impression" threads. Keep em coming :).
About 3" forward of the handle.
Seems functional to me. Nothing to write home about, but certainly a good sheath for strapping to a pack.
Instead of rivets, I do wish they'd used eyelets so the sheath would have more lashing points.
With machetes, you often don't get a sheath, or if you do, it's a cheap POS. This one is actually pretty decent.
Only one I have is the Cutlass. The Grass Machete's blade isn't as wide, so I give the edge to the Cutlass (more blade weight at point of impact), but the GM is still a fine chopper.
For batoning, it shines because of that nice long blade. You've got plenty of blade to work with and beat on with a baton log.
Guyon, thanks for the impressions and pictures. This is the 1st time that I have gotten a good look of the Machete and I'm very impressed! Looks like it has 2 different grinds before the edge interesting...
This is my next blade purchase, Already have the cutlass and the kukri from the ka-bar copper line. The Kukri outchopped the cutlass, I thought, but the cutlass was certainly no slouch, and has a few pros of it's own. So far these Ka-bar choppers have really impressed me a lot, I am surprised they are not a lot more popular, actually.
I feel the same way, budget choppers usually get more work than the higher priced ones, mostly, because of the price.
Throw in some awesome quality, and boom, instant hit.
Moose
please help me out... the website says its the same thickness as the kukri... .165 i have the kukri and its a stiff blade. ill pry out chips while im cutting... thats what makes it a knife and not a chete. i need to know if the grass machete is in fact the same thickness as the kukri or is it 1/8 (.125) like you said? also if you dont mind could you pinch the knife in between 2 fingers at the point of balance and post a pic? i need to see the balance... the grass machete is said to weigh 1.2lb on the site while the kukri weighs 1.7lb. considering all of the data on both blades what do you think is accounting for all that missing weight considering the blade is the same thickness and longer?
Welcome to the KA-BAR forum, and Bladeforums, v5gg. Glad you stopped in.
The Biscuit is a little bit busy right now, trying to get over a nasty cold, so, lemme see if I can help.
The Grass Machete (GM) is .165 thick, not 1/8. Its stiffer than you would imagine it being, but the Rockewell is held a little lower, allowing the GM to be more flexible and not chip or roll.
The GM weighs 1lb 4.5oz on my scales. You have to keep in mind, the blade is longer, but there is less metal there. The Kuk a wide broad flat stock blade, where the GM has the baffled edges and a high grind.
Balance point pic, righ here.....
Is there anything else or any other questions you might have? I've used mine quite a bit trimming branches and bushes around the house here, and its a beast, a true beast.
Anything else you need, just let us know, we'll do our best to help out.
Once again, welcome, stick around, I'd like to hear what you think and what you decide.
Moose
need to get me one of those soon.
awesome thanks alot. im definately gonna get one in light of the new specs. im a bit bummed about kabar messing up multiple specs on the website. this is as thick as the kukri as i thought from your pics. it looks just as thick as my kukri. i dont know the kukri's REAL weight but this one should be just a little lighter. the longer blade and forward balance will help offset the weight and this will be a great one for brush clearing and building things (due to the straight edge) this paired with a medium or large axe would be all you need in the woods. thanks again!
You are most welcome. Stick around, I'd like to see what you wind up with.
Moose
Im not sure how I missed this thread but I love my cutlass. I was close to getting the Kuk or the grass so I just went in the middle. I really like the handles on them but I would pay the difference to have stacked leather!
I was going to get one but instead I ordered a worksharp and some kydex supplies and built a press. soon. very soon...
