A teensy bit more info would be good. For instance, what do you mainly plan on using it for?chriss said:What are some pros and cons of a black USMC Ka-Bar
It is a bit big for that. Unles you wish to chop wood try something smaller.chriss said:i plan on getting the serrated one and using it for hunting camping hiking and fishing
I will second the recomendation for the shorty, really easy to carry around but packs quite a punch when you need it. For example, i just used it to de-vine the front of my house, a dreaded chore, but the kabar made life much easier. It is a really manouverable knife, but the saber grind leaves a lot of weight for chopping small wood (under an inch). For hunting and fishing though, it might not be the friendliest geometry, because the saber grind will make slicing things precisley dificult. (however, it will do fine if you keep it sharp...for example, it outcut my moms henkels kitchen knives that were 2 years old and occationally steeled when i tested the two on a roast.) I guess the point there is to keep your knifes sharp, because thats more important than geometry (the minime kabar is at least 3x as thick as the flat ground kitchen knives.Blue Sky said:I found the full size version more than necessary for most things. Consider the Kabar "shorty" version. Same design, 3/4 the size. I've carried one for years as my roving, hunting & fishing knife, no complaints. Does what a knife needs to do.
(Oh yeah, welcome to BF!)
