shaving sharp
- Dec 19, 2007
I just got my BK-2 knife and I must say that it is an excellent heavy duty knife and at an excellent price.
What I plan to do here is make the knife into my ultimate survival package by doing some modifications and additions to the knife and sheath. I will post the progress here so you all can see what I have done and what you think.
First the sheath.
I think the sheath is excellent and the fit and finish is first rate. I think that the stock belt loop is too long and soft. I purchased an Esee RC-5 Molle back and PSK pouch and decided to change out the factory belt strap and add the pouch.
Now, it is not a perfect fit but with a little work here is what I came up with. A word of caution if you use the top hole on the sheath it makes the knife way too tight in the sheath and very difficult to remove so I used the second hole. I also had to zip tie thru the bottom holes to lock it together good put it under the strap so it would not rub on me.. I think it works pretty good and makes the package alot more useful.
Next will be knife modifications which I am going to keep to myself for now but will post step by step modifications as I do them.
First the sheath.
