rpttrsn I don't understand your angle adjustment. It looks like the table and platen move together?
I have the same angle adjuster on my kalamazoo. It works great as long as you can hold the knife parallel.
I mainly keep mine on 19 degrees which works out for most knives. I will adjust for filet and fine chopping/dicing knives though.
I also have a extended platen on mine as it looks like you do too.
Have the Kalamazoo for years. Great for sharpening knives. Have 60 to 6000 micron belts. Also leather belt for stropping
Can adjust grinder to any angle or leave at 90 degrees.
Thanks Ron, I’ve been playing with a similar setup of paper wheels + grinder and I find the grinder easier to use too.Case Peanut,
When I first got the paper wheels I played with them for some time. Did not find them as comfortable as the Kalamazoo to use. Only one grit for sharpening and the grit didn't seem to last on the wheel. The stropping wheel using different rouge works pretty quick then I finish up on leather strops. I do have laser lines going across both wheels from above which puts me on the angle I want. Have set the wheels up with a separate motor and pulley so the speed is not as fast as most grinder motors. Many are happy with the paper wheels. Its just not my first choice in power sharpening. Still the Kalamazoo works the best for me.
Ron
