- May 31, 2011
Took another shot earlier today at a project I'd spent some time on previously without success. Specifically, I wanted to attach the Twice as Sharp scissor sharpening arm from my TAS-Pro to my Kalamazoo belt grinder, so that I could make use of the belt grinder's slower abrasive speed and vastly better heat control capability. Also this would allow me to use the large assortment of belt-based abrasives I have in place of the two (rather poor) abrasive options the stock TAS offers.
The first attempt I made was rather less than successful, I simply tried drilling a hole in the work rest and bolting down the TAS arm. Unfortunately, the work rest proved to be insufficiently rigid, which resulted in a lot of vibration and a less-than-optimal edge. This time, I took another approach to it. Little bit of cutting, little bit of welding, a couple of hose clamps and presto! A removable, adjustable, ridged-as-can-be support for the TAS arm. One 1/4-20 UNC-2A SST bolt later, and the TAS arm is now a fixture of the Kalamazoo, sharpening in the slack of the belt for a slight convex, just above the (Mark Reich modified) platen.
Going to give this one a shot this afternoon and see how it comes out! I have high hopes for this mod, the rigidity problem that the previous attempt had should be entirely resolved now.
