I've been designing an oven with using Kanthal A1 wire.
If we compare 1,2mm & 3mm wire with the same power value
For 4000W and 230VAC according to the ohmage chart we should use these lengths below;
1,2mm wire length should be: 13,6 meters
3 mm wire length should be: 84,8 meters
But I've got a question;
Do they heat up to same degree at the same time or the thin wire will heat up more because of its small diameter even though it has the same power value with the thick one?
The points that important for me are;
Reaching a specific degree (1000Celcius degrees for example)
with a small amount of time possible
with a long heating wire service life.
Thanks.
Thanks.
