I have been carrying one of those Katz for years. Good solid folder, feels like a fixed blade. That black plastic thing is a bit on the large size. I left it in place, but mine has a small phillips screw that holds it in on. Try removing the screw, it should just come off.
I suggest filling the hole with a black epoxy such as JB Weld. It won't be invisible, but I think it'll look decorative. Try a black crayon and see how it looks. Crayon might work as well as epoxy, come to think of it....
I have not removed mine, but I think that hole would be very tiny. If it really bugs you, and don't ever plan to put the thumbstud back on, then I would just tighten remove the thumbstud, and then put the screw back on real tight, and grind the head off so it is flush with the spine. It should be quite invisible afterwards.
