No, I tested both motors by themselves, w/o anything attached to the shafts. First the 2hp 3600RPM Emerson, that I got for the HMG "New Jersey". That was
my first experience with VFD and when I bolted it down to a massive wb, hooked it up , no load on the shaft and it started vibrating,I figured this is the way it is supposed to be and hoped that when I attach the driving pulley to it and bolt it down to the bench, the vibrations will diminish to where I won't mind it. Also I thought may be motor is to be blame.
Although I bought both of them brand new from Grainger and made sure they both are "inverter duty" rated.
So, 3 or 4 weeks later I got me 9x20 lathe and started thinking about converting it to the VFD, using the KBAC I had. So I bought the second
motor, this time 1.5Hp 1750 Dayton. Bolted it down to a WB, BY ITSELF, no load. Hooked it up to the VFD (after changing HP setting to 1.5HP) - it vibrated even worse ! Clearly it was totally not useable for a lathe!
I reached out to folx and asked if it is normal with VFD, was told: ABSOLUTELY not. It should be smooth as silk . I tried loading the shaft
of 1.5 HP with a chuck off my 7x14 - same story, really bad vibrations that
only disaapeared at the highest RPMs (1750 for this one).
So I called the KBE, had 2 separate guys listen to both motors (to answer possible question: ONE at a time, the KBAC is wired with L14 female and motors both have L14 males).
Off the bat they heard them vibrating and told me something is wrong. By that time I had checked the wiring about 1000000 times. I rechecked it AGAIN. I measured the line in (AC), the rectified voltage (DC) with KBE guy on the phone and it all checked out.
Now, the motors are in perfect balance and if I spin them up to full RMPs
and then CUT OFF power to KBAC, they instantly loose all and any vibrations/noises they are making with KBAC and all I hear from them is
slight hiss as they coast to stop. No vibrations of ANY SORT.
So yes, I am a frugal dude and do have duct tape on my 11" contact wheel.
Yes, I build my own grinders - 2 by now. Loved 1st, loved knifemaking and upgraded to 2nd model - that I modeled after Bader/KMG. Used the money I saved to order 2x2, 2x3, 2x8 polywheels from SunRay .
But, this has nothing to do with the problem @ hand, as the KBAC makes
the motors go crazy w/o anything being attached to them. 2HP by now
has a well balanced 5x2 driving pulley (bought from SunRay, I didn't have
the 9x20 then and could not turn it myself). Same story - it vibrates.
On the 1.5HP motor, I tried a chuck from 7x12, that I KNOW is well balanced, as I routenely spin it @ 1500 rpms on the lathe. Same story - it vibrates.
Now let me qualify vibrations: it is really more of "beats". May be 3-10 of them
every second, depending on RPMs. REALLY powerful beats - they shake a 400LB workbench !
So ... the 1.5HP motor went back to Grainger. Full refund, 0 hassle.
2HP stays attached to the grinder.
For vari-speed conversion of my new 9x20 I ordered a DC motor and controller
from SurplusCenter. I simply have no trust in VFD anymore, although I know
thousands of them are used for lathes/mills around the world. If I could dump the KBAC at not too great of a loss, I will probably spring for Toshi, LG, etc, NOT KB.
Still there is a 1 in 1000000 chance that there was a piece of debri inside of the case that was shorting something. Now, as the motor bounced through
FedEx, it got shaken out and now it works. Lets see if I am that lucky
The motors both were wired for "LOW VOLTAGE" :
- T4,5,6 tied together and left hanging
- T1-T7 is attached to one of the output legs of KBAC
- T2-T8 - 2nd leg
- T3-T9 - 3rd leg
Ground from breaker panel is not fused, goes to the ground "green" lug on KBAC and from there, another wire goes to the motor's body, grounding it
as well.
If I swap any 2 "output" legs on KBAC, both motors reverse. I tried about every POT, every jumper in the KBAC, to no avail.
The KBAC is 15 feet of 3x12 gage wire away from breaker panel.
Motor is 4 feet of same gage away from KBAC
