- Apr 13, 2005
Just got off the phone with KB Electronics. I have a 3HP motor 3 phase and asked about the KBAC-29 about the 1PH 220 V in and 3 PH out... He said it runs the same as the KBAC-27D in this application. The problem to me was the amps.... since it is higher than (not much more than a 2hp) what the 27D calls for. He said that running a belt grinder 2X72 will work and if there are any problems by overpowering the motor the unit will trip and not cause damage. The amps is the maximum load of the motor and will not need the high amps for grinding since we are not "laying into" the blade with out weight for more than 15 or so minutes.
He added the 3hp motor has more windings (copper and such) in it to make it withstand more heat from loads. Since we are not running large conveyers he thinks I will not have a problem.
Why a 3hp...... I have a new motor sittin in the floor. I just wanted to share this information as it may help someone else out.... I have not tried this yet but I will get another grinder set-up in the near future.
Daniel Prentice
Daniel Prentice
