- Feb 22, 2019
I could get all that black off with acid in a few minutes.That's just minor finish wear imho, I call them love marks and leave them on.
Happens to all black finished knives if you use 'm.
Here my BK7 for reference
I you dislike it.... grinding the black of is way too drastic, removes too much metal imho
Depending on the type of black coaring you can try panit stripper and hand sanding/ polishing after stripping. Maybe just the bevel and notbthe flats to get a fancy look.
Those teeth look very rounded btw, not sure how they look on new kabar knives, but getting those crisp and sharp again would worry me more than the black finish.
If you don't mind it, leave it. If you want to remove it, I recommend citristrip as a chemical stripper. Here's a before and after of a scrapyard 311 I did.
I also stripped all of these, accept for the middle one which I bought already stripped.
It's pretty easy to do. With the leather handle, it would probably be good to wrap that up for protection, but the synthetic handles (micarta, g10, rubbers) tend to hold up just fine to citristrip.
I have a brand new bottle of aircraft. Would that work
And no I havent sharpened it yet
I think the Kabar knives look handsome with the paint stripped off. I used off the shelf paint stripper from a hardware store, and the stuff just wiped off. Any stubborn paint in the nooks I took off with the flathead screwdriver of a SAK. Just a bit of pressure and it peeled off.
You know, after a couple of times of plunging the blade into sand
will sorta give it a distress finish...
But yeah, its a lot faster to run it over with an abrasive rotary device.
