- Sep 19, 2017
After tumbling with some creek rocks for a few hours, dipping quickly in hot Multi-Etch, and then anodizing at 77.5V, these are my Keen scales:
Thanks.Looks pretty damn good, but I thought blue was further down in the voltage?
Ah. I've only seen rough charts of the process. thanksThanks.The spectrum is somewhat periodic, meaning that some colors repeat -- among them, purple and blue. You could say that there's a "low blue" and a "high blue."
No problem. It's actually somewhat difficult to figure out without experimenting on the piece you're anodizing, because the exact color you'll get at any voltage is going to very strongly depend on what the surface is like. Shinier surfaces look very different than rough surfaces, as the voltage gets higher and higher. And if you want to make it even more complicated, if you don't use Multi-Etch (or Whink, i suppose), to take off the surface oxides before anodizing, the colors look different yet again. I thought I was going to use 81V, based on previous experience, but due to this surface treatment, it turned out that the blue colors started much earlier than they did for me other times. Anodizing is kind of a pain in the ass.Ah. I've only seen rough charts of the process. thanks
Thank you again. I've been experimenting for a few months, and that's how I learn. It turns out that you can do a whole lot with relatively little equipment. With a simple rock tumbler, creek stones, ceramic media, burnishing solution, Multi-Etch, 110V power supply, and a Dremel, you can stonewash, shine up, anodize, and shave off hotspots. One cool trick is to shave off hotspots, which ordinarily leaves bare titanium that doesn't match the existing ano. Well, just give your piece a dip in ano, and make sure to anodize just below the existing color, and the bare titanium will now just about match the rest of the knife. You can really do quite a lot with not too much. Which product(s) can't you get ahold of?What makes it worse is when you can't get a hold of those products, and you have to guestimate
It is a very interesting process nonetheless, and your Keen is one of the better looking "amateur projects" I've seen anyway,
I don't want to say that there's only one way to do something, but usually, to achieve two distinct anodizing tones, you anodize, tumble with some coarse media or stones in a rock tumbler or a vibratory tumbler, and then re-anodize at a second tone, where the second tone is lower on the voltage scale. (Always anodize at your highest voltage color first, tumble, then anodize at your next lower voltage, and so forth. So, for two tones, you just anodize at the high voltage color, tumble, and then re-anodize at the lower color.)I have a purple Keen/Laconico coming one of these days.
How can I tune down the purple and perhaps achieve some kind of blue and blue-black?
I have some very basic anodizing supplies and chemicals from Home Depot.
