Try to clamp parallel to the spine of the blade and closer to the tip (the clamp centered about on the middle of the blade should be about right). The DMT plastic holder may flex some causing this kind of thing. The Lansky doesn't hold the blade as firmly. For a long time I used my DMT "stones" and holder with a modified lansky holder (I machined a notch in the clamps to give the spine of the blades something to register on) and that worked OK.
FWIW, I've found that just about every blade I've sharpened had some issue with the primary grind, either it is crooked, or not even or something, so often there is some spot on the blade that can't be made entirely perfectly even, at least not without excessive grinding, sometimes this becomes an issue of weighing blade life vs imperfections you're willing to live with (like in this case, depending on how much it bothers you you may want to just leave it and fix it incrementally as it needs to be re-sharpened, for me, based on your picture and the blade style the very narrow secondary near the heal would bother me more, but with flat stones you won't be able to fix that without grinding out the slight bit of recurve between the heel and the belly of the blade, I'm not sure if it's worth it, again, I would probably leave it till it needed to be re-sharpened). If you end up getting seriously into trying to get this right you move things around till you get things as even as possible and then grind both sides even before you do anything else (If you're using the DMT holders do some digging, there are some really coarse DMT stones that are intended for other uses that fit those holders that cut much faster- faster cutting/less pressure = more consistent grind angle... I have a black and a grey that are much more coarse than the average, I also have finer green and tan)
Finally, that looks like a Hinderer spanto tip- they will always end up with a wider secondary bevel where the primary bevel breaks near the tip... nothing you can do about it unless you want to grind it into a tanto, it's the design of the blade. Where that gets weird is that I've seen them with the break in the primary bevel in 2 different places on each side of the blade.
