So I found a "Genuine Norlund" axe head on my parents property while visiting and doing some yard work for them. Booya!
It was buried a bit and seeing as this is washington, covered in rust. The eye of the head still had a broken portion of the haft and (what I presume is) the original, barbed steel wedge in it. It was a real bear getting the wood out. After removing the rust, I found the head was more pitted than I had surmised. So I scrapped the complete restoration idea and changed to a "fatigued/functional" look. I cleaned all the rust off except in the pits, then washed with muriatic acid. The acid helped clear out the rust, and etched the steel. Interestingly, the acid etched a clear line, apparently from a differential hardening.
This axe seems to be high quality. I sharpened the edge to 20 degrees per side and then bought a 3/4 length ash haft (24") and dyed it. Now, the question: is this an heirloom quality tool I should hang onto, or, being a poor college student, do I flip it? I don't know anything about axes. Thanks! :thumbup:
