No not that
I am trying to finish up a one of my first hidden tang bowies. Todays challenge is getting the pin holes drilled. I am in the fitting stage before heat treat. I oops'ed the hole for the tang and it's a little sloppy (Well OK it's ALOT sloppy
) I wrapped it with a layer of tape and that helped. Problem is there is about a half a hairs gap between the back of the gaurd and the front of the handle. I Can see it so it bugs me.
How do I sinch this up so the pin holes will come out right. When I hold it tight with the blade in a vice, the gap dissapears.
How do I do this so I can use my drill press, to do the pin holes?
Is there a device that clamps the blade and pulls the handle in tight at the same time?
RHankins Available knives
http://albums.photopoint.com/j/AlbumList?u=205453
