PZ93C:
A good solution to this and other belt-related carry problems is the Safariland 1 1/2" synthetic gunbelt. I have been using one as a through-the-loops pants belt for the past several years and they work great - won't wear out and will support anything that can be carried around the waist.
The gunbelt has hook & loop fasteners on the inside surface, which can be used in conjunction with an "underbelt" passed through the loops on one's pants. The "underbelt" has fuzzy-side-out velcro and can be worn very well by itself.
With the underbelt in place, all that is necessary is to place the gunbelt over it and press in place. Items on the belt can be positioned anywhere regardless of where the pants belt loops are located. Once the belt is on, the stuff on it doesn't move.
Underbelts are cheap and if you change pants alot during the day you can keep a couple all "looped up" in your prospective pants. If the velcro connection is not secure enough for you, you can make velcro "keepers" to hold everything in place out of self-stick velcro strips available at sewing-type stores.
This sounds like alot of fooling around, but it works very slick and the belts are not expensive. Also, they don't look like gunbelts and you can wear them every day without inviting comment.
