I use my blade at work alot. I often cut boxes open and my blade gets tape on it and its annoying and leaves this residue marking. Does anybody else have this issue? What do you use to clean it?
I don't really clean my work knives... I have a separate one for that... my carry knife I don't cut stuff with... but to remove tape residue i'd use some wd-40
I just rub it off with my fingers from the spine side so I don't cut myself and then get the last bit with a papertowel with Rem Oil or whatever oil I have on hand to prevent blade corrosion from the salt in body oils and sweat.
WD-40 and Goo-Gone are good for getting adhesive residue off the blade. Nevr-Dull is good for getting all the metal residue and stuff off the DLC coating (like if you cut a tin can in half with a coated blade).
Oil from your nose, WD-40, lighter fluid, etc. all work very well, but it's still a pain when you know that the blade is just going to get gunked up again the next time you open a package, which could be five minutes afterward. So, I suggest getting one of these (the cheaper the better):
