keeping blade clean
Is there anything I can put on the mirror finished blade of my sekicut to help the fight against fingerprints?
Thanks,
Richard
I use Nevr-Dull. It is used primarily to remove stains, but after you polish it off it has a 'dry lubricity' that helps polished finishes. I buy it in cans of reasonable size, but I've heard that they sell it to truckers at Interstate gas stations in huge containers.
http://www.autogeek.net/nevwadpol.html
Try "Flitz" metal polish. Non-toxic, rust remover and seals the blade against rust.
It is a very fine abrasive, so don't use it on anything with coatings or a beadblast finish as it will eventually wear away.
Can I use Flitz on the blade and then use the knife to cut fruit? Also, what do you guys use to clean your blade after you cut some fruit? Is it ok to rinse it with water and wipe it dry?
Thanks,
Richard
