How do you keep the front piece of handle slabs all lined up and straight? I am more interested in if you are working on a really small knife, say about 1" x 2". I know if it is a larger piece I can use clamps and such while drilling the pin holes to keep everything nicely aligned.
I am putting the CF handles onto the knife I ground from a talonite sample, and the front pieces of the handle slabs are not aligned properly. I first drilled my holes in the tang, and then used them as a guide to drill my holes in the scales. My problem was that because the piece was so small I couldn't get things where I wanted, clamp it up and then drill. I had to hold it together as I was drilling, which is no doubt why it came out the way it did. Anything I can try if I decide to make another small knife? Thanks in advance.
