- Aug 28, 2009
A while back I was going to move my grinder and such into a storage area in the house. I have since decided against it because the area acts like a sound chamber and amplifies every little sound. The room is too small to do any sort of sound deadening in so I am just going to use it for finish work and hand sanding for the winter.
Right now I am working in an uninsulated garage, it keeps me out of the weather and wind, but it does get cold in there. I will be adding a forced air heater to keep myself warm while working, but it wont be enough to keep the grind bucket from freezing up. A quick and time consuming solution would be to just dump the bucket every day after I am done, but to be honest I am a little too lazy for that. The only other things I can think of is adding some sort of antifreeze to the bucket, or getting one of those livestock water heaters to keep the water from freezing.
The heater idea has one big negative that I can see, and that is the constant power draw yet the water will never go below freezing. With the antifreeze I don't know if it will cause problems because of the chemical make up, and what happens when a hot knife (from grinding) gets dipped into the below freezing water?
Any suggestions would be appreciated here. I am trying to keep operating cost as low as possible and that includes the possibility of ruining a piece of steel because water temps or belts because of chemicals.
