Cliff Stamp
BANNED
- Oct 5, 1998
[WARNING THIS POST IS RATED NC-17 - CONTAINS REFEFENCES TO BUSSE COMBAT, ACTUAL FACTS ABOUT PERFORMANCE, AND MAY BE DANGEROUS TO THOSE WHO LIKE TO OVERHYPE PRODUCTS - READER DISCRETION ADVISED]
First a shot :
http://www.kellamknives.com/catalog/mline/mtbillhook-w.jpg
The Billhook weighs 250 g, the plastic sheath is an additional 60 g. It is ground from forged carbon steel, 0.115" thick. It has a single grind, 0.275" wide forming an edge of around 10-12 degrees per side with a very slight secondary edge bevel, probably formed with a buffer of 14 degrees per side. The blade has a black teflon coating.
NIB the Billhook was very sharp, easily push shaving, scoring 122 +/- 17 g on light thread and push cutting 3/8" hemp at 31-35 lbs, which is actually better on both counts than many light utility folders I have seen, let alone blades meant to actually do serious wood working.
With this in mind and being in a fairly silly mood anyway I used it for some light utility work and it actually did very well on many things such as cutting cardboard, ropes and such, it isn't a very good potato peeler, however if I had to pick it or many of the tactical knives I have seen for utility use I would readily take the Billhook.
Onto more sensible use, I used the Billhook and my straight handled Battle Mistress (SHBM) for some light weed and small wood cutting. The BM was freshly sharpened, readily hair popping, however even though the Billhook was not quite at that level, it did hook through the weeds nicer and was lighter in hand, it didn't take long to realize that the Billhook was a much more efficient tool. I then moved to some light woods, Alders and the comparison went much the same way.
I then switched to a Murray Carter Camp knife, much thinner edge than the BM and lighter, but it could not match the Billhook either. Plus it was a little less stressful to use, whack a $400 custom Carter into some weeds and smash it into a rock may seriously dampen your mood, you just keep hacking with the Billhook.
Onto some limbs, the Bowies had better relative performance than on the lighter vegetation but the Billhook easily kept up in terms of cutting ability, was lighter, had a very nice handle and the back was thin enough to smash off some of the gnarly dried branches anyway so you could readily spare the edge.
However with some thick wood work, the comparison flopped. The Murray Carter Camp knife is very smooth, it almost glides in and out of the woods, while the Billhook gets stuck and doesn't have the same penetration. But the Carter took a serious ripple on a knot while the Billhook plowed through knots with no hesitation.
In short this is a very solid tool for light vegetation, weeds and even small brush, it doesn't work well for thick wood, the blade is too thin and jams, but can be used in a pinch, and will even baton wood, though again will bind excessively. It is very sharp NIB, the edge retention is solid and the sheath secure.
The only downsides are that the sheath is plastic, the retention strap a plastic loop which I think will break with repeated work and I would like a longer blade. But if you are looking for a serious limbing and brush tool, this is definately worth checking out. I look forward to hacking away with this seriously the summer.
Ref :
http://www.physics.mun.ca/~sstamp/knives/billhook.html
-Cliff
First a shot :
Ref :
-Cliff
