- May 4, 2007
I'm looking at the WSKO with the attachment videos on Youtube and reading through forum posts, and I'm left with a question that probably has an obvious answer once you actually use the device.
So the first step is to place the knife on the lower blade rest, I guess to set your muscle memory to what is horizontal. Next, you lift the knife several inches to a position above the first roller. That's a lot of space where a variation from level/horizontal can occur.
Has anyone fabbed a tool rest directly above the first roller? It seems like it would be a no-brainer to keep your knife completely level as you move it across the belt.
Here is a quick and dirty concept of what I pictured:
Would obviously need an adjustment point or two based on the angle you set, but seems, at least on paper, like it would give more consistent results.
Thoughts?
Thoughts?
