- Nov 16, 2002
Don't have my own pics or pics from the place of purchase, but the Kershaw 1710 is a $10 3-fingered lockback. It has an adjustable pivot, is otherwise riveted closed, and has no nail-nick, thumbstud, opening hole, or flipper. You have to pinch the flats of the blade with your thumber and finger... ...like a savage! :barf:
The blade is made of mystery stainless from the increasingly freemarket People's Republic of China and is a spearpoint with a slight distal taper and a high hollow-grind. The blade wasn't that sharp out of the box and the grinds were uneven. Owning a $20 Vapor, I was surprized. Also, the edge is fairly thick for such a skinny blade. The steel is soft enough that it may be quickly remedied with a belt-sander or diamond hones. Unless you suffer from edgorexia nervosa.
Had lots of boxes to cut down today. All were corrugated cardboard and all had gianormous staples (easier to avoid). Due to its thin profile, the 1710 cut fairly well, but it dulled quickly and I ran back to the power-strop several times. Finally, it got tiresome, so I turned to my Spyderco ATR with Phil Wilson heat-treat and convex edge. The ATR readily outcut the 1710 and stayed sharp much longer. It's a rare day when a $190 knife out cuts a $10 by leaps and bounds, but that was today.
If I didn't just receive the moras and Opinel, I would've been more impressed with the 1710. It cuts well and resharpens quickly. It's small, compact, and has an adjustable pivot (a top reason FRN-handle-haters choose for hating FRN-handled knives). It may be worth it to pay the extra bucks to get the Onion-designed Vapor or Storm knives or save $2 and get an Opinel.
