- Apr 15, 2002
I got around to using the Kershaw Blackout that Dennis sent me last week. His main reason for sending the knife was, I believe, to allow me to test whether assisted opening knives are less suitable for a wet or dirt prone environment. I haven't gotten a chance to take it on my boat yet. The weather is still too windy to go fishing.
First let me say that this knife is superior to the other 2 Blackouts that I have experience with. Those knives both seemed fragile. This one is a stouter folder. The plain edge part of the blade came hair shaving sharp, typical for most every Kershaw folder I have experienced. The serrations had noticeable burrs or dings in the edges of all of the large scallops.
I am neither a fan of assisted opening, liner locks, or thumb studs and this knife has all three. The assisted opening gets the blade out and locked with a flick of the thumb. Rolling the stud with the ball of the thumb engages the AO but the knife won't open completely or the lock won't totally engage. My guess is that flicking the stud lessens the contact between thumb and blade whereas rolling the stud, my finger remains in contact a split second too long and fumbles the opening, preventing the AO from positively opening the blade.
I have been flicking the thumbstud to get the knife open but I can already tell that this is going to be uncomfortable with perpetually wet hands and impossible with the gloves that I wear. Here is where an assisted opener benefits infinately from a flipper. Luckily Dennis sent a Shallot as well.
I have only actually used the blackout for one day. I mainly cut polypropylene rope that was either frozen or encased partially in ice. If I were to buy another blackout in the future I would select a plain edge. The serrations on this Blackout, my brother's Blackout (exact same knife) and my old Vapor 2 leads me to believe that Kershaw's serrations leave something to be desired. (I am specifically describing the "Spyderedge" style serrations here, consisting of one large scallop and 2 smaller ones)
After cutting only rope, the points on the serrations bent noticeably. They are not blunt, the tips did not break off, they bent. It is easily detected with a fingernail that a significant amount of every tip is bent towards the unground side of the blade.
Kershaw seems to grind the edges of their knives at a more acute angle because this particular blackout came razor sharp, mirror polished, and seemingly with a very thin edge. It sliced paper and shaved hair with ease. After a couple of cuts on the rope, however the plain part of the edge was noticeably deformed. It reflected light in multiple places but there was no detectable (with my fingernail) burr or rolled edge. It was still "sharp" though it did not shave hair.
Most likely I will keep using this knife to better get to know it and it's full potential. The coating held up extremely well and although the blade was wet and not wiped down afterwards there is no rust spotting on the edge or coating. For some reason the FRN handle feels much more slippery than I had expected and may pose an issue when using the knife while wet.
The thumb stud is set up for right handers only, as is the clip. The clip isn't reversible. The stud and clip screws are all phillips screws and the thumb stud appears to be reversible for left hand use. I might try this and see if it is possible. The clip is matte black, but not a "painted" on coating. It doesn't resist scratches but they do not show up like they would Spyderco's painted on clip coating.
I will continue to update this thread periodically as I use the knife more.
Pete
Pete
