Kershaw Cyclone dissected & blade polished (lotsa pictures)
Hi *@*,
a few days ago I got my Kershaw Cyclone and I really like the knife so far. Good ergonomics, solid lock-up and the sharpest out-of-the-box production knife I ever got (sharper than my Spydercos or my Benchmade Skirmish!). In fact on my first try to open it with the thumbstuds I promptly cut myself. ;)
The assisted opening feature is working very well when the flipper is used - but when you use the thumbstuds in the usual way you have to be really *extra* careful to not to flick your thumb right into the edge (which is just what I did).
Anyway, the only thing I really did not like was the satin finish of the blade .. so I took the knife apart to repolish it! Sooo .. here are some photos I took for your viewing pleasure: :D
Cyclone taken apart:
Blade polished with 600 grit paper:
And the other side: :-)
The scratches don't look as bad in real .. it's just very difficult to photograph the blade.
It's getting late here so I have to finish this tomorrow with the 800 and 1000 grit paper I bought for this little project.
Prepare for more pictures! :cool:
[UPDATE]
Ok, this took me a little longer than I expected :) I polished the blade with 800 and 1000 grit .. it was still quite dull after this, so I decided to polish it with some Flitz which really made it shine alot more. After I was done with the blade itself I also polished the liners and the copper (?) washers with Flitz .. this stuff really makes a difference to metal, wow. A few drops of Militec-1 in all the right places and now the Cyclone is better than ever, the action is ALOT smoother than before and I really do like how the blade looks now.
It's not perfect but hey, it was my first try at this. Took me about 7 hours altogether (much more than I expected).
So here are some pictures of the finished knife for you:
-Connor
Was it satin finished or beadblasted? Glad you took it and made it your own, but (just from pictures), I would have preferred the non-reflective original finish. Then again, the finer the finish, the lower the friction in cuts. It's all a tradeoff! And it lives in your pocket, not mine.
Oh- I just saw you were still using higher grits to polish it. Good idea! Take out all of the swirls. I'd heat up the thumbstuds (use a heat sink) and remove them to get them out of the way, and loctite/screw them back on later.
I UPDATED my post with new pictures! (see above).
To be honest .. I am not sure if it was satin finished or beadblasted. Whatever is cheaper, I guess. :)
I really didn't like the original finish because it looked just dull and grey and somehow cheapish to me.
-Connor
pretty decent job, bead blast sux rocks.
i would have tried a hand rub/scotch-brite finish.
that way you got an excuse for the scratches.
the circular motion is painstaking unless your willing to go up super high like 2000 or above.
-Connor
Now that you posted a new picture of the finish you put on, I prefer it to the beadblast. It looked way too shiny in the first two.
Nice finish! I've polished up a couple of mine too, and really like the effect. My next project is to thin down a blade and re-finish. I is a mirror polish so I may have to be brave.
Greg
I did pretty much the same thing with my framelock Leek, but I started out wetsanding with 1000 grit followed by some Flitz with a dremel felt wheel to polish. I did the blade and handles and I like it a lot, the laser etched "Kershaw" and "Ken Onion Design" are like ghost images now still barely visible.
