Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
As most of you know, I prefer a blade with the tip near the bottom, lower than a regular drop point, up from a wharncliff, what I call a modified wharncliff. I have the Kershaw Double Cross, excellent knife, smaller brother to the Kershaw Double Duty, shown here. But you'll notice that the blade in back isn't a Spey blade any longer, more along the lines of a Muskrat style blade that really cuts great with a more piercing point. The thumb stud did limit my grinding down on the blade but it still came out nice and more serviceable than before. But there are those that may like the Spey blade, all the more power to ya! This knife truly cuts well, two blades, old style package with a twist, thumbstuds for opening, the liner is cut on both ends to allow the blades to be liner locking. On the Clip point side, the liner had a promient raised portion, didn't like that, stuck up a bit too high, ground that down to a more user friendly size, also not in the way when using and less likely to accidentally release and close that sharp blade on your fingers!
The steel is AUS 6, a lowly cousin to the higher grades out there, but it does take an exceedingly sharp edge and has kept it fairly well, I like it!
The handle is long and thick enough that the knife made an exceptional good apple peeler, didn't lose the knife in your hand and wasn't too big that it allowed you to rotate as you did the peeling, it's a simple test of dexterity I give a knife, check our your favourite folder to see how well it handles an easy everyday type task like that.
So, thumbs high for Kershaw, I recently got this, have always admired it but didn't care for the Spey blade and with owning, I took the liberty to repair what I didn't like
G2
G2
