kershaw ken onion linerlock
deltablade
I just got a new Ken Onion liner lock, and noticed the liner only touches about half of the blade when in locked position, that is the liner moves over when the blade is opened to lock in place behind the blade, yet it only moves over so that half the back of the blade is not touching
Is this a problem?
Which model is it? If it is a thicker liner then it will probably be alright as a little time will allow the liner to move over and become set in behind the blade tang.
db, is the entire face of the liner lock making contact with the blade? If so, then that's the way it should be. Now, if there's part of the liner lock that isn't touching the blade, then you may have a problem, Houston (I've been looking for a time to use that line here!)
