I think he means the relief cut. The knockout is a sub-frame lock. The lock bar is not cut out from the handle scale. It is a steel bar that is attached to the aluminum scale with screws. Look I inside the handle with a flashlight and you will see what I mean.
It's to bad there is no local store here anymore that carry's higher end knifes that you can look at before buying them.
I'd like to see the knock out and find out if any other knifes were ever made with that design. If not they will probably be a good collectors item.
