- Mar 9, 2005
Here is a webpage with the Kershaw Speed-Safe knife disassembled. Check it out.
http://home1.gte.net/res0ak9f/1leek.htm
gdavis9999 said:I noticed that if you tightened the pivot screw down just enough to 'hold on', the blade will hang up.
How tight do that come from the factory?
Are you supposed to tighten it up just until you feel a little resistance then fix it in place with locktite blue (or perhaps even red??)
Thanks in advance for anyone who knows....
gdavis9999 said:Here is a webpage with the Kershaw Speed-Safe knife disassembled. Check it out.
All are broken, though not in two separate pieces.gdavis9999 said:Did your bar break or just loose it's 'spring' ???
