I have a used Kershaw Leek (Missing safety and clip screws) and JYD2 I would like to give away to someone. However, you must meet the following conditions:
1. Basic member status or higher.
2. Each knife will go to a different person.
3. You own the knife you are asking for in some sort of PE configuration. Steel doesn't matter for the Leek, for the JYD2 only the 13C26 version is applicable because the SG2 version has a different grind. They must be relatively close to the factory edge angle and have been used, or the owner must be willing to subject them to use.
4. You must agree to use the knife you receive for everything you would normally use a knife for and then post in the review forum how the knife performs compared to your original Leek or JYD2. This includes re-sharpening.
5. You will do with the knife as you please once you've met the previous conditions.
