- Nov 24, 2005
I just recieved a new Kershaw Random Leek 1660TGRYST yesterday. I bought it as a back up since my older one has developed vertical blade play, I think because the steel lock bar is softer than the S30V steel tang.
Anyway, it arrived and wouldn't open past 1/3 rd of the way out. ARGGH - since the older one is faster than a switchblade. Next problem is that the blade is off center.
I tried backing off the pivot until I got blade wobble and it barely opens enough to allw the lock bar to close. Adding a drop of oil only slowed it down, so I rinsed it out with alcohol and proceeded to work on the blade centering.
After many queries I found some helpful threads (old threads from this forum actually) which didn't do a darn thing. Here:
http://www.bladeforums.com/forums/showthread.php/696581-Kershaw-Leek-blade-centering
http://www.bladeforums.com/forums/showthread.php/676100-Quick-Kershaw-Mafia-Question/page2
Ive loosened pivot and screws and tried to slide scales, push the blade over and using the Spyderco Military centering method with a cardboard shim in place as I tightened up the screws.
I'm frustrated with this little bugger after spending a couple of hours on it and still having an "I don't wanna open, off center knife." This model isn't exactly cheap either.
I called Kershaw yesterday and I was transferred to the warranty dept. but they were out. I left a detailed message as requested on the machine and my phone number several times very carefully. Does it take them a day or two to call back or do I call again? Also, if anyone has any tips other than what I've tried and linked to, please share okay?
Thanks!
Thanks!
