I think I can,but is it ok if I use vaseline or I need to buy grease ?It is normal per say... You need to add some grease to the speedsafe torsion bar. When the grease inside dries up or whatever they start to rattle. You can probably send it to Kershaw to have them do it if you cannot.
Ok, so I need to use grease.I wouldn’t use petroleum jelly as a melting point is just above normal body temperature.
I've never really thought of what you could use other than grease but as mentioned above some things will work better than others. Grease is idea and normally what is used. Check your garage or a friend's house to see if they have any type of grease. Automotive or not should work. Pretty inexpensive at the auto parts or hardware store.Ok, so I need to use grease.
