- Aug 20, 2006
I heard a rumor that the Mini-Mojo blade was listed as 440A steel, but was really Sanvik 13C26. Can anyone confirm this? Thomas, Tim?
nygiantsfan3342 said:Good enough for me, I don't remember where I heard that. Would have been a cool marketing error though...Like getting steak when you order hamburger!
Artfully Martial said:The AO did break on mine really quickly (last about a month), but it works fine as a manual now.
nygiantsfan3342 said:Like getting steak when you order hamburger!
I think 440A is closer to 440A, or itself. 440A has way more chromium.iceaxe said:More like getting ribeye when you order sirloin -- depends almost as much on the butcher and chef as the beef. 440A is very similar to AUS 6M/8 -- kinda like AUS 7. It'll take a wicked edge and though Sandvik may hold an edge longer, it's a lot easier to get that edge back on the 440A. I have a CRKT Walker Bladelock in AUS 6M that cost $35. Great edge out of the box and still has it.
BTW, I love my Mini Mojo. Very addiciting little bugger.
It shouldn't be the steel that makes it hard to sharpen, I bet it's an edge geometry thing. Unless they've never sharpened anything harder than 52 Rc.Artfully Martial said:My friends (the storm owners) have experienced difficulty sharpening it though...
Well, I didn't mean anything specific, I've only used one Kershaw knife, I was just making a general statement about difficulty in sharpening.Thomas W said:Dang Larrin, you and Cliff getting on us about edge geometry and our grinds is starting to make us a bit self conscious.
iceaxe said:440A is very similar to AUS 6M/8
Larrin said:It shouldn't be the steel that makes it hard to sharpen, I bet it's an edge geometry thing. Unless they've never sharpened anything harder than 52 Rc.
I agree, but if someone was used to sharpening soft steels, it might be initially difficult to sharpen a hard one.Cliff Stamp said:In general, steels tend to get easier to sharpen as the hardness is raised...
Cliff Stamp said:AUS-6A is basically Sandvik 12C27 with a small amount of nickel and even smaller amount of vanadium, so you would expect the performances so be similar in many respects with AUS-6A having a finer grain and slight benefits to wear resistance from the small amount of vanadium. 440A is a very different steel, it has a lower maximum hardness and much higher volume fraction of primary carbides. It also has better corrosion resistance but much lower edge stability and ease of sharpening.
How they are hardened would be of critical importance as most really underharden the inexpensive alloys because they are used on inexpensive knives.
In general, steels tend to get easier to sharpen as the hardness is raised for several reasons, often simply because the properties for knife perforamnce are often increased. The edge is likely too thick given the geometry specified on other blades but there is also a big difference in trying to achieve very high sharpness with a fine carbide steel and a very coarse one.
Take a x-coarse hone or even a file and hack the primary edge bevel down to 10-15 degrees per side. Apply a secondary edge bevel of 20 degrees per side. It will quickly stabilize and should then sharpen easily. If you are just doing light cutting you can go thinner still, however it depends on your skill/experience.
-Cliff
