spyken said:Also, the heavily recurved blade wasn't very efficient and wasn't balanced like a machete ...
Penetration in wood wasn't the best with the factory edge (too thick I think).
I'm selling mine and sticking to locally made parangs / goloks.
whitedoor said:Is there any word on how the Kershaw Outcast is holding up? I remember there were some questions regarding whether D-2 was appropriate for a larger chopper blade.
Cliff Stamp said:Nick if you have the means to do so, adjust the primary grind to reduce the edge thickness to something sane like 0.025". It will not only increase cutting ability greatly (reduce impacts and feedback, promote higher precision, reduce fatigue, etc.), but make life a lot easier when you apply a relief grind to get a wood working edge edge angle. You do not want to end up having to sharpen an bevel a quarter of an inch wide with something with the horrible grindability of D2. If you leave the edge at 1/16" thick this is the type of extreme width you will end up with with a high relief grind.
-Cliff
