Yes the handle screws are under the inlays and they are glued in place.
Another member detailed how you can heat the inlays with a blow dryer or heat gun, soften the glue and then pull up the inlays.
Or you can do what I do with my Tyrade.... not disassemble it. I clean my Tyrade by spraying a liberal amount of RemOil into the pivot area and then shaking out the excess. RemOil is a light lubricant with a cleaning solution.
I must be that member! The inlays are easy to remove using a hair dryer, or heat gun. Just start on one edge and once the edge is loose place a very thin screwdriver, butter knife, or whatever fits, under the edge and gently pry up as the glue gets warm and releases. I used super glue to put them back in and have had no problems with them.
