Kershaw Vapor bent blade?
I've got a vapor...and it seems that the blade curves to the right..(if you look at it from the top, with the tip pointing away from you). Is this normal? Or a defect?
this does not seem right. Perhaps you could show us some pictures? If it as extreme as it sounds you should definately get in touch with kershaw. They apparently have great customer service.
Well it isn't extreme.
Perhaps only noticeable when you examine it in detail. But if you examine it, it is there. Just wondering if this is normal, a part of the design or if it is defective. I dont' remember prying anything with it.
I have a NIB Queen Utility that is off center. I consider it a defect but, still use it as it is not worth the trouble to return it.
