- Oct 13, 2014
I purchased a Kershaw Volt SS and have been handling it for a few days and opened and closed it at least a few hundred times or more. I'm having a difficult time releasing/unlocking the frame lock and want to know if other owners experience the same issue.
As a reference, I own the Ontario Rat 1, Spyderco Tenacious, SOG Flash 2, Kershaw Cryo 2, Thermite, Scrambler, Volt 2, all knives were between $25-40 delivered. My first impressions are negative and positive:
NEGATIVE.
1. It's difficult to release the frame lock to close the blade with one hand. When trying to release the frame lock, if holding the knife in your right hand palm up, the right thumb has a difficult time trying to release the frame lock. The frame lock is has no jimping on it, so it's slippery, and it is not raised much as compared to the opposite side, making it difficult to release in normal warm dry conditions, cold and wet conditions are going to make closing it more difficult. If you use your left thumb nail/tip to push down on the frame lock, it's easy to unlock, but that requires two hand closure and pressure on your thumb fingernail. The frame lock appears to be slightly higher than the non frame lock side, about 1/64", but it is not high enough. My lock release on my Kershaw Cryo 2, Kershaw Thermite, Kershaw Scrambler is raised about 1/32" higher than the non frame lock side with no jimping on it, which is not high enough. My Ontario Rat 1 is raised about 1/32" (not enough) Kershaw Crown is raised about 1/8"(easier), Spyderco Tenacious is raised the highest, about 1/4" (the best), with these 3 having jimping on them. These 3 are easiest to close one handed. The Spyderco is the easiest to close one handed and could probably be closed with gloves on. The bottom line is that the frame lock or liner lock on all knives should be raised about 1/4 of an inch or more and have jimping on it for easy closure, similar to the Spyderco Tenacious. I'm not a knife maker. It's Kershaws job to figure this out and build knives using this simple solution. This one simple fix would have been all this knife needed to make it perfect. I don't think I got a defective knife. I think this is the way they are manufactured. I'm going to contact Kershaw and get their opinion on it.
I contacted Kershaw explaining this, and their response was I can return the knife and get my money back. That's not the problem. The problem is the way the lock release is designed. The lock release is not raised enough to allow the user to unlock it with one hand.
NEGATIVE.
