Kershaw Volt SS Owners - Does it open by accident in pocket?
Basically title.
I'm interested in the Kershaw volt SS because a friend just gifted it to me for Xmas, but I never had assisted flipper knives, do they open while I carry them in the pocket?
I'm very scared of that, that's why I always carried fixed blades. However I really like the Volt and heard only positive things about it by folks, so I might try this folder assisted flipper, but would like to know if it does deploy accidentally while carrying it in the pocket.
That was my first “modern” knife by a reputable brand and the only assisted-opening knife I’ve owned. From what I remember, it took a lot of pressure on the flipper tab to open it. I don’t think this was because of the detent itself but due to the spring for the assisted opening.
I've been carrying Kershaw Links for a while, which is also an assisted flipper, and I'm never had any issues. It takes pressure parallel to the blade, so if you bump against something it doesn't do much.
Edit: Link not Grid.
Edit 2: parallel. You have to pull forward or back, not apply pressure straight at the tab. Stupid brain.
I got a few A/O knives
Always carry them inside pants pocket
Never any problems at all
Don't worry
There’s a million pocket knives that aren’t flippers, or assisted, and you’ve never tried any of those either? Even a slipjoint?
My edc needs aren't that high, in fact I just bulk buyed some CRKT scribe (that's what I meant with "always carried fixed blade) because I didn't had to worry about them deploying by accident.
I could also be a fan of slipjoint, but they are usually without a clip so I never went for this route.
Since with the Scribe I could feel safe in carrying it and it did the small jobs I do with a knife daily, I never bother trying other stuff. Another reason for me not checking on folders is because I suck at mainteinance with them, I don't know anything about it. I do not own knife oil or other stuff people usually suggest, in fact, I only own a little Fallkniven CC4 sharpening stone, some screwdrivers for the torx screw of knives and that's all I have, knife related.
However, since I got this kershaw as a gift, and I'm not gonna lie I really like its aesthetic, blade steel and everything I would gladly carry it instead of the scribe and now that I see that people (Thanks for the replies guys!) are telling me it won't open in the pocket & how to carry in a more safe way I'm more prone to try the folder knife route, even though I still know nothing about folder mainteance
This long, a bit OT, reply is to explain that while accidental deployment was one of the reason I never approached folder knives, it wasn't the only one
No problems with my Leek, although I did change the clip to tip up which I prefer for fast deployment, plus it places the blade up against the edge of your pocket in case something were to happen (it’s not).
The only way to carry is tip up so the blade is trapped closed by the seam of your pocket even if it does manage to escape the detent, tip down is for super squirrel vest-wearing weirdos who belong in The Hague and people who need to carry their knife somewhere other than their right front pocket.
LMAO I'm dead. ROFL
M minibus93 , man you’re missing out! You definitely need to use that folder. As far as maintenance, they are pretty easy. Don’t worry about taking knives apart or anything like that, most times hot water and soap will keep them clean and there’s plenty of lubes you can buy to keep the pivots free moving, even plain old mineral oil from any pharmacy.
As you know from looking at kitchen knives, carbon steel will rust and patina, stainless steels are less care. If you enjoy that folder you will want another, and should! There’s many out there for budget and bargain prices that will serve you well.
The only way to carry is tip DOWN so the blade is trapped closed by the seam of your pocket even if it does manage to escape the detent, tip UP is for super squirrel vest-wearing weirdos who belong in The Hague and people who need to carry their knife somewhere other than their right BACK pocket.
Fixed it for you!
Tip up... it puts the "pocket pecker" deeper into the pocket; where there's less chance of any serious entanglements with it.0609 Martin 02a.jpg
... Another reason for me not checking on folders is because I suck at mainteinance with them, I don't know anything about it. I do not own knife oil or other stuff people usually suggest...
I'd recommend seven maintenance essentials but you already have Torx wrenches. :)
1. Mineral Oil - The cheap and non-toxic stuff you can buy at any pharmacy. While some people say you don't need it for stainless steel, I always like to rub a very small amount onto metal surfaces after cleaning with alcohol or other solvents. (This is more important for D2 or non-stainless steels.) Yes, you could use it to lubricate the pivot but I prefer a slightly different weight/viscosity...
2. Lubriplate FMO 350-AW - This stuff is great for knife actions! It is non-toxic and originally designed for food prep machinery. It caught on in the gun community and turns out to be excellent for folding knives too. Another benefit is that it is dramatically less expensive than specialty "knife lubes" like KPL. One bottle will last most people for several years. This is the best place to buy it online.
You might want to get an empty bottle with a needle dropper from Amazon or your local hardware or hobby shop. It helps for adding just a drop right where you need it.
3. White Lightning Crystal Grease - This clear and non-toxic grease was recommended to me by a Kershaw employee. If you ever end up taking your Speedsafe assisted knife apart for a full cleaning or other maintenance, a dab of grease is recommended for the torsion bar. This is the best grease for the job. I've found other uses for it but like the Lubriplate above, one tube will last most people for several years.
4. Isopropyl Alcohol - This is good for general cleaning and degreasing. It got harder to find since the pandemic but it's still cheap and effective. You'll want the highest concentration you can get. Especially at 91-99%, it evaporates very quickly and pulls moisture with it. That can be handy!
5. Dust-off - Often (and erroneously) called "canned air", the little straw attachment is extremely helpful for drying an action when you can't or don't want to take your knife apart. (This can be helpful if you have water in your action, and is doubly effective if you flushed out the water with concentrated alcohol.) You can also use it to push oil up into places if needed. (Wear safety glasses whenever squirting or spraying solvents.)
6. Zippo Fluid, aka Ronsonol - This stuff is perfect for removing tape gunk from a blade. Seriously, it works. Just squirt some into a paper towel, wrap it around the gooey mess on your blade, wait a few seconds and then wipe it away. This has been a fantastic find in the era of shopping online and opening a bunch of boxes.
