- Aug 20, 2009
Hi all!
I have now carried and used Kershaw Zing 1735 OR. And I decided to give my impression and more about mini review:
The Good:
+ Ergonomics
+ 3 way carry
+ Solid Linerlock
+ Sharpness out of box
+ Light and slim
+ Fast deployment
+ Sturdy pocket clip
The Bad:
- Polyamide edges on handles were sharp and rough.
- Handle torxes portrud above the handles.
- Pocket clip is hard to use in thicker places.
The Ugly
* Rust spots on Bead blast after few month carry even with light oil coat
Zing is excellent utility knife. Orange version is also easy to spot and makes knife less dangerous looking for sheeple people. Some handle fit & finish were not up to Kershaw's level. The only real ugly thing was rust spots which appeared on bead blast finish in relatively short period even when blade has light oil cover. On the other hand I do live literally stone throw away from the Baltic ocean. Salt water is bad enemy of steels. Winter's are not helping either but on the otherhand I've carried Skyline almost as much and it hasn't got any rust spots despite same finish.
The lock up is very solid in Zing. I have never while using Zing needed to fear lock might fail:
The spine thickness of Zing is a lot thicker than Skylines. This add's sturdiness of to the blade. Perhaps in some task spine is bit too thick. Spine could have been thinner without affecting performance anyway.
There's one thing I noticed: While many people complained about Zing's plastic washer's I did found out that they work well. I had few times when temperatures below - 15 degree's C problem with Skyline with regular metal washer's problem of opening. In Zing's plastic washers I found to be more pervious against frost.
Now in future I would like to see Zing with G-10 scales and DLC tungsten coating or TiNi coating for improved corrosion resitance.
Some pictures of portruted torxes:
Zing compeared to Skyline:
The Good:
+ Ergonomics
+ 3 way carry
+ Solid Linerlock
+ Light and slim
+ Fast deployment
The Bad:
The Ugly
