- Jan 10, 2001
It came today (record time!, Sorry Brendan, and guys below the equator
) I've had the YCS on my lust list for some time, as well as an "old style" dui chirra. I think this is a good blend. Several of the kamis did a "make what you want" blade a few weeks ago, and Uncle said Kesar was too steady for that - just wanted to produce pattern blades. The temptation to go on his own may have produced this trio. Whatever reason, the variance from the model did not produce anything resembling a bad knife. Steel fittings, dui chirra blade with deep belly (2 1/2") and a 7/8" spine. The inlays are as advertised, but nothing that I can't live with. One "dot" jarred out of an "eye" inlay has me looking for some 3/16 black nylon rod I saw a month or so ago (damn memory) and one of the kardas took a shot. Nothing that some happy tinkering can't fix. Kesar chose a perfectly straight-grained piece of Saatisal for the handle (better to cut for inlays than burl or heavy sap grain). This is the kind of Saatisal that looks drab, until a few coats of oil light up what is underneath, or causes the heavy black lines to disappear and reappear when the handle is turned ("gotta-be-a-pony-in-there-somewhere" wood).
Balance is just 1 1/2" ahead of the cho. Fullers are regular and uniform, but don't lighten he blade that much - they are well defined, but not as deep as a Chitlangi's or a GS'. The flat spine only tapers from 7/16" to 3/8" at the beginning of the drop, and a gradual taper to 1/4" where the edge bevel comes up to take it to the almost chisel point, making the blade appear massive, but the balance makes it light in the hand. The little Khukuri voice started talking immediately "I like to chop, I like to slice, and I can draw cut better than anyone". And I think it just might be right
This one could end up in a hand-tooled leather sheath.
