Kesar v. Murali: Two M-43s Faceoff
Folks:
Despite Mr. Clifton's nefarious plot to corner the M-43 market, I've managed to acquire two of these guys over the past few months. Here's what happened when they got loose.
The Perpetrators
Edit - The Forum won't let me post a pic in two places, so here's a link to the infamous "Ignore" thread. The M-43s are at the top.
http://www.bladeforums.com/forums/showthread.php?s=&threadid=206485
Kesar M-43
OAL: 17 17/32"
Blade Length (from front of bolster): 12 15/16"
Blade Width (@ cho): 1 1/4"
Blade Width (@ sweet spot): 2 5/16"
Blade Thickness (@ cho): 1/4"
Blade Thickness (@ bend): 1/4"
Blade Thickness (@ forward grindline) 3/16"
POB: Approx. 3 15/16" from front of bolster
Max. Handle Diameter: 1 1/8"
Wt.: 27.5 oz.
Murali M-43
OAL: 18 1/4"
Blade Length (from front of bolster): 13"
Blade Width (@ sweet spot): 2 3/32"
Blade Thickness (@ cho): 10/32"
Blade Thickness (@ bend): 11/32"
Blade Thickness (@ forward grindline) 1/4"
POB: Approx. 3 5/8" from front of bolster
Max. Handle Diameter: 1 1/4"
Wt.: 26 oz.
Here they are. The first acquisition was the Kesar (bottom khuk in pic). It is definitely different from any other khuk that I've handled. The pistol grip and broad belly make it very weight-forward. But, the handle is a little short and it doesn't move like I'd prefer.
To be blunt, I didn't really like it. At first, I thought that Mr. Clifton was welcome to all the M-43s that he could stuff into the Cave. I figured they'd make great kagas katnes. But, rather than write-off the much-hyped M-43 design, I decided to try another when the opportunity arose. So, along came the Murali.
The Murali is a separate beast, as you can see from the pic. The old two-smith's-interpretation bit, I guess. Unlike the Kesar, the Murali's handle is straight. It's blade-mass is distributed very differently than the Kesar khuk. The Murali is longer and leaner with a much more neutral feel. Also,it's fit and finish are more crude than the Kesar's, but that doesn't bother me.
I did a little work with the Murali when it arrived, and, while it performed very well, I still wasn't convinced. So, I decided to see what the two could do if given a real chance. The one that I liked the best, even if it was only relative, would be kept. The other would be sold.
The Crime Scene
Since I didn't want to make my building manager nervous by swinging steel on the side lawn, I set out to my folks' place in the 'burbs. There, the blades preceded to assault a series of victims, starting with...
Victim 1: 1 1/2" hardwood dowel
This provided the chance for both blades to face a uniform target. Both the Kesar and the Murali cut through in 4 strokes.
Victim 2: 2" cherry tree
In situ chopping was next on the list. My dad was interested by this point, so we proceded to the woods behind their property. The first unfortunate we encountered was a 2" cherry tree. The Kesar went to work.
Smack! Smack! Smack! The sweet spot seemed to guide itself to the target with each swing. The blade bit deeply, but did not bind. 7 blows later, and the poor cherry was down.
Victim 3: 2 1/2" cherry tree
This one was dead, but the bottom was solid. The Murali took this one out. The blade did not bight as deeply as the Kesar, and I had to make a conscious effort to apply the sweet spot. Still, it did not bind, and it moved faster than the Kesar. 12 strokes, and this cherry was ready to be made into kindling.
Victim 4: 3" hickory
The Kesar took this one on. 12 hits and down. Again, this khuk seemed to have eyes of its own. Either that, or it's all sweet spot.
Victim 5: ?
This one was covered in creepers, and I couldn't see the leaves clearly. My dad, who's fairly woodcrafty and good at id-ing trees and wood, called it a "jack" tree. Personally, I think that meant he didn't know jack about it.
This took 81 hits with the Murali before falling. Still, it took less than 4 minutes to accomplish and cost me no fatigue. However, the Murali twisted in my hand on two shots. I think that was due to the size and configuration of the handle. It has a couple of uneven spots which work against a good hold.
Victim 6: plastic jug
The final test was against a water-filled detergent jug. Since this was one of those impact-resistant polymer deals, I didn't expect much from either blade.
The Murali sent the jug flying. When I retrieved it, there was a 1" long cut on both sides of the jug, but only a dent in the middle, where the sweet spot struck.
The Kesar did the same, but made longer cuts on the front and back of the jug. I've never cut plastic bottles before, so this may not be unusual, but I was a little puzzled.
After having a couple of days to think about it, I have to admit that Jim is right. The M-43 is a great design (particularly the Kesar rendition). It's not one I'd choose for MA work, but it makes a top-notch utility blade in my hands.
Which one am I keeping? BOTH! (Sorry, Semp.) With work, I think I can get the Murali's handle where it needs to be. I like the heavy-duty nature of Murali's rendition (thick buttcap, heavy pins holding the handle together, thick blade). But, the Kesar and Murali are so different that I don't know that I'd call both of them M-43s.
S.
Edit - !@#$, photos didn't post. I'll try them separately.
Spence, it pleases me that the Kesar M43, which I believe you got from me, has worked out so well. You should see the M43 I kept!
--Mike L.
I have an 18 inch 28.3 ounce Murali M43. I had put a thread on the Cantina about it when it arrived a few weeks back. It feels wonderful in the hand and looks great. However, over the last couple of weeks I completed a fair bit of cutting on Cadagi tree branches up to a maximum of 5 inches in diameter. My 16.5 inch 28.7 ounce Chiruwa AK is a far better chopper. Even my 15 inch 25.7 ounce Chiruwa AK appears to cut the branches better than the M43. After a fair bit of chopping, I also noticed that the M43 has about 4 waves along the length of the right hand side of the cutting edge. I didn't notice these at first and since noticing them I have done a fair bit more cutting and they don't seem to be getting any worse. I don't know if the waves were there to start with or developed later. I can feel the waves when I run my hand over the right hand side of the blade but they are almost imperceptible to sight. Strangely, the left hand side of the cutting part of the blade appears perfectly true and smooth. Even though it is one of my prettier khukuries, I probably am a little disappointed at its performance.
Spence,
The best M43, I've ever tested is the one & only one I have by Durba! He's gone & I've seen nothing closeBUT I keep hoping!!
jim
Clifton, how many 43's do you really have? I know it's tough, but tell me the truth for once.
Otherwise I'll tell the dancing girl you like best, the one with the cyanide capsule tooth, to break it open during the throws of love and exhale it into your waiting corpse.
munk
Hey Spence - great review!
Nice to see the blades get put to the test.
Set some of that hickory aside and let it dry out - I can put it to use. :) I'll come by and pick it up - perhaps if we ever get around to having a DC meet.
Glenn:
I remember your thread. I snaggged my Murali around the same time, but I didn't pick it up (the package, that is) for awhile after you got yours.
I didn't have any issue with the Murali blade's hardness. In fact, it seemed to get sharper with use. (Pappy has mentioned this "self-sharpening" phenomenon before. I just thought he'd spent too much time in the hot Texas sun. Guess not. All I can say is...weird.)
If I had to surmise, I'd say that the waves were in your blade to begin with. As I mentioned, I've found Murali's work to be very solid, but a bit crude.
Given the way Murali distributes the steel on his M-43, I can understand that it wouldn't be the best heavy-duty chopper. I sort of view the Murali M-43 as heavier-duty, chiruwa Sirupati. At least that's how it feels to me.
S.
I have a Murali M-43 as well. the blade is excellent ! a 10/10 effort.I repeatedly wailed on a piece of seasoned East Tennessee hickory as hard as I could.. no blade damage what so ever. The only regret I had was the finsh work on the handle and bolster could have been a lot better.
munk,
Truthfully,"only one"!!I no longer have wealth, I'm just a poor,humble,"RETIRED researcher!! GONNA ASK PALA IF I CAN DONATE SOME ITEMS FOR HIM TO BUY & SEND UNCLE!! HAVEN'T BEEN ABLE TO EAT,(COUGH,COUGH),ANYONE WANT TO DONATE,YOU ALL KNOW ,SO I CAN GET ONE MORE K! ROG, (SNIFF,COUGH,FORLORN LOOK)HOW ABOUT HELPING THE POOOOOR
OLD RETIRED RESEARCHER!!
jim
Ok Tsimi. Your pitiful whining:barf: has broken my heart:rolleyes:
I've been waiting for this moment so you can FINALLY be welcomed into the waiting arms of The Center for Light and Reason!
Yes my son ( work with me here) any khukuri I have is yours with your admission that I am right!
Operators are standing by to get your address and phone number to send even ( gasp) one of my Durbas! You can join Me ( Dr. Not so Evil), MauiRob my personal hero and mentor, Semper Fi my bodygurad and Chief of Security and so many other open eyed believers.
THE...the..."POODLE" IS YOUR bodyguard! heeeee!Bwaaaaa!YOU WANT ME TO JOIN THIS..THIS BUNCH OF LOONIES!Bwaaaa!MY ANSWER TO YOUR REQUEST IS...:barf:nOT EVEN "LITTLE J" BEGGING COULD GET ME TO COME OUT OF RETIREMENT! :D
jim(more Sainty than ever):cool:
Spence, you have made me feel a lot better about my M43. It's amazing sometimes how looking at something from a different viewpoint can change your feelings. I had read somewhere that the M43 was a great chopper. When mine couldn't compete with my AK's, I was disappointed. It's sort of like someone telling you how great a movie is and building you up for an unrealistic expectation. I now realise that M43's differ probably more that any other khukuri from one to another. You're right, Murali M43's are more like a heavy duty Sirupati and differ from those M43's made by other kamis. When I view it from that point of view, I can see its uses. As noted previously, its grip and balance are wonderful and its weapon potential is obvious. I now see its potential for lighter chopping duties - my M43 has just jumped back up into my list of favourites.
