- Jun 25, 2001
OK guys finally after two plus years I need some help
I picked up a Pilot less gas valve kit
$32.00
it's a conversion kit for a LP or Nat Gas heating unit and I have the orfice to convert it to LP gas..and will be using LP..
I have the valve, the ele control for the Valve , and the igniter / sensor,
I need now
a thermocouple, the thermostat control,
and a transformer 24V.< no prob on this one..
the question??
this unit is set up for max 1/2 PSI with 1/2" in and 3/4" out, good volume I'd say and hopefully will over come the lack of pressure max settings,, factory set for
11.0 W.C and I can set up to 12 W.C.
which I believe will make in one place it says
200,000 BTU's and in another it says 320,000 btu's
will this be hot enough for the forge and the salt pots??
I'm thinking yes because of the volume ??
now I have more paper work than need be with this thing and with cross numbering it's a little confusing..
on the Valve unit it says
Robertshaw-grayson
7200iper-s7c
7e2-e7b-029 Max 1/2 PSI
Reg. Nat 3.5" W.C.
24 VAC
0.4 Total Amp.
720-07K
first will this work for what I want to do with it?
and next what do I use for a thermocouple and the thermostat control with this unit..
I need now
the question??
Robertshaw-grayson
7200iper-s7c
Reg. Nat 3.5" W.C.
24 VAC
0.4 Total Amp.
720-07K
