Key cutter
I know this may be far fetched but has anyone thought of using a key cutting machine for a baseline setup for patterned blank cutting? Obviously it would need to be modded and would likely be only for smaller blades. Just throwing it out there.
Keys are brass. Are you suggesting steel could work on a key cutter?
No I was thinking using the machine as a basis for patterning since it already has a mirror image patterning design feature. obviously the wheel would need to be changed and other mods but who knows it may have a use in knifemaking.
I don't see it being very effective/efficient, even with mods. A wheel small enough to have any definition would likely not last very long. I imagine you'd want to rough most of the material off of the blank before hand, at which point it's just as fast or easy to free hand the pattern with a bandsaw and/or belt grinder.
If you're looking for repeatability and precision for a moderate number of blanks, I'd just have them waterjet cut and be done with it.
Short answer - it won't work.
Longer answer:
Duplicators for cutting steel are ten to twenty times sturdier and heavier than a key cutter. The motors that turn the cutters are also 10 to twenty times the power of a key cutter.
You would need carbide cutters and a large coolant flow.
Waterjet, laser, and CNC plasma are also twenty times faster than using a key cutter to make profiles.
Just the cost of trying to convert a key cutter ( which wouldn't work well when done) would be enough to cut a lot of waterjet blades.
I have an old key cutter somewhere out in the storage building that I tried to use to make serrations. Even for that simple task, it didn't work. I had better luck converting a powered chain saw sharpener to get serrations … and it didn't really do a good job.
