KeyCom 3D
I made it in 3D program. And key was added at the end. I have no idea if its in correct ratio. Probably not.
Wow, this looks like an awesome little knife. It looks like the ergonomics on this baby are going to make it a cutting machine. This is der shcizzle.:)
thanx for the sweet pix Tomso (awesome rendering) & Man of Iron (care to translate to English? lol ;) ) :cool:
the looks of the Edit has got me psyched!
That looks fantastic, I have already ordered two and now I feel vindicated. You sir are an artist.
-Mat
jaislandboy, the descriptions on Edit and KeyCom will be on Bokerusa.com soon, but the texts aren't always the same. I can translate it for you, but ain't got the time, sorry knifebro. :jerkit::jerkit::jerkit:
"KeyCom - It gives EDC (Every Day Carry) an entirely new dimention. With a size of 5.6cm (closed), it's possible to carry it on a keyring without problem, and moreover this knife of the Chad Los Banos's Designs simply has steady ergonomics and utility value day to day. Incl. keyring. Framelock, glasfiber reinforced plastic outer scale. Blade steel AUS 8, steel pocket clip Tip-down. Total 9.6cm, blade 3.8cm. Weight 39g."
Okay, I did it. Now leave me alone :p Learn German and read the Edit text yourself.:D:D:D *TEASE*
thanks bro ;):D
Well Man of Iron;
To prevent Brian from buggin' us i'll give it a shot;):
Translation EDIT (post #7)
The Edit is the newest design by CLB in the Compact fixed blades segment.
With an overall length of 13.6 cm and Bladelength of 5.2 cm the genious ergonomics gives an extreme secure grip, in which the jimping of the spine will give the Thumb even with strong handling a secure hold.
The lanyard (included) will easy the drawing of the knive and on the other hand work as an extention of the handle .It will support the pinkfinger a holding base while working. The bladestrenght of 3.5 mm adds to minimizing the overal weight to just 65 grams without compromizing the stability.
The included Break-ball chain allows set up as Neck knive. Alternativaly the zytelsheath(?) can be carried on a belt with a small Tec-lok (not included). Blade steel AUS-8 with a special Titanium coating.
Note: the text says something like Artificial fabric sheath. I guess it will be Zytel like the MPT sheath.
Danke Maarten :p
Your German is definitely better than mine, I tried a little, but gave up after the 3rd sentence. Their style isn't the easiest to read, and some wrong spelling. Damn, and I'm supposed to read Kant (Kritik der Reine Vernunft), Nieztsche, Heidegger etc. in German:grumpy:
Just smuggle in some translated versions of these nasty books ....;) Some awkward sentences used i agree. I think you did a fine job on the keycom translation.
Tried to PM you but no allowance...
How the heck can I find the pm? I'm a no paying member. (cheap bastard):p
Man of Iron, you do not have permission to access this page. This could be due to one of several reasons:
1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Go to top left User CP . Here you can alter your email settings. If you allow members to pm you they will not see your email adress but still can reach you.
