Khuk comparison
I have bought 10 khukuries since I received a rather healthy dose of HIKV. I've given four to family (18 inch WWII, 15 inch Sirupati, 15 inch AK, and 17 inch BGRS), kept three, and have a BAS and two villagers somewhere in the mail on their way to me. The three that I have kept are a 19 inch Chitlangi (by Kesar), a 17 inch BGRS (by Bura), and a 16 1/2 inch Chiruwa AK (by Kesar). The weights of the three in the order above are 21 ounces, 23 ounces (as measured by Bill) and the AK is heavier (but its weight is not known - I don't have any kitchen scales). All three have wood handles. Their lengths of wood in the handles are 5 inches, 4 5/8 inches and 4 1/4 inches in the order above. The main reason I kept these three is that they fit my requirement of being as big as they can be to travel all day comfortably on a webbing belt.
Prior to doing any work with these three, the BGRS and Chitlangi were my favourites. All three look spectacular but these two are just so light and quick to swing. Their handles were also bigger and felt more comfortable. Also, the handle on the AK was a tight fit for my hand size and the sharp end of the butt appeared to dig into my palm. I have to admit though that I prefer the look of the Chiruwa handle to the other two. It appears chunkier and the contrast between the light and brown streaks in the wood grain is more pronounced and I just like the look of a Chiruwa handle. One paradox for me is that my daughter has a 15 inch Chiruwa AK that is basically the same size as the 16 1/2 inch when in the scabbard. I am not sure what happens to that extra 1 1/2 inches in the scabbard.
My favourites changed order when I spent about 2 hours chopping. I am fortunate in having a couple of Cadagi trees in my backyard. The lower branches are about 4 inches in diameter. I spent my time today alternately using the three khukuries to cut some of these lower branches into 12 inch lengths (but kept quite a few branches on the trees for future khukuries). There was no real comparison in their effectiveness. The Chiruwa AK was by far the better chopper. The other two were good on branches less than 4 inches (as was the AK) but were significantly less effective with 4 inch ones. It could be simply the heavier weight, but whatever it was, the AK cut at times as if it were slicing butter. The problem with the handle disappeared when used. In fact, the tight fit seemed to lock my hand in and the problem I had anticipated with the butt end cutting into my hand did not eventuate. The AK also had a property that Yvsa once mentioned with some of his khukuries, wherever I aimed with the AK was where it hit. The other two were not as consistent. I felt no jarring with the Chiruwa handle that has been reported by other members of the Cantina. In fact, my initial impression is that there was less jarring (I know that doesn't sound possible but I think it is because each cut with the AK went in deep and the other two stopped faster because they didn't cut in as far - terrible explanation I know).
All three finished the session in perfect condition. All three blades are wonderful. But guess which one is now my favourite. I am now trying to think of what to buy next, M43, 21 inch GS, YCS? I'll wait till the BAS and two villagers arrive before making a decision, but after this experience, I am seriously thinking of another 16 1/2 inch Chiruwa AK, but this time with a horn handle and embossed (worked, engraved, I am not sure what you call it) scabbard. My daughter's 15 inch Chiruwa AK is horn with an embossed scabbard and it is just so beautiful to look at. The only problem is that even two khukuries of the same size and type can have different performance. I think I have struck a gem with my Chiruwa AK.
Yeah, the AKs are for me, too. I like the 21" GS a bunch, but its edge geometry suggests lighter cuttings tasks, but its light weight suggests all day use. The AK i have is 18", over 2lbs, and built like an iron bulldog.
If the AK can't cut the target material, then it'll just bulldoze thru anyhow. My cutting tests with the AK against 1 inch plywood (edge on) yielded 4-5 inch deep cuts with practice, and 2-3 inch cuts without much arm power, just using arm for steering.
I think there was some talk about Uncle Bill using one to crush cinderblocks or bricks or something? I cannot bring myself to do that to a blade unless necessity calls for it.
The AK is an axe in a knife package, that's fer sure.
Keith
Glenn,
Let me tell you about the next stage of the infection.
You will run into a job where you have to clear some plants with light flexible stalks. Your current favorite will do the job well, but then you wonder about one of the thinner blades. When you try it you find that it sings through the job. It becomes your new favorite.
Then one day you need to behead a kangaroo…
The khukuri is a multi-purpose knife. The insidious part of the HI marketing scheme is that some models do some jobs slightly better than other models. Any one of the knives would do most of your knife jobs for life, but there is this irresistible desire to get the “best” model for each job. As many different jobs as there are in the world, that’s how many khukuri designs there are.
Enjoy your remaining sanity.
Finding the best khukuri is one of our disire, but doing test for all candidate khukuris side by side, in a rain of woodchunks falling upon me is also as alluring.
I like emotional side of Glenn's fielad report. I'm inclined to try out my 20" AK, 18" GS, and 17" BGRS. Thanx, Glenn, for new interest.
...And to think that the locals in Nepal can get by with just one. Perhaps they choose the one that fits their body type, and make it the one that does all of the jobs? I bet Sher could use one of his own beefy AKs for anything, and everything (well, maybe not for tooth brushing - you gotta use the Karda for that) heehee.
Keith
