- Jan 17, 2002
Yesterday I damaged my 15' AK Kesar user khuk. Since last may, I used this one almost on a daily basis for firewood chopping, camping and making coffee
. I like to think I got pretty experienced with it. For some reason one hit went wrong, the khuk did not hit the firelog in the center resulting in the blade delving full speed in the ground. It hit a stone.
I examined the edge and saw that it was damaged near the tip: a chip of about 4 mm long and 2 mm deep was missing. At first I was ready to hang this one on the wall and wanted order a new user. But then I remembered that I had a coarse Scandia stone somewhere and decided to try to restore the edge.
After a couple of strokes from the belly to the tip I saw that I could easily restore the blade line. The coarse grind takes metal away in a very controlled matter. Since you use no power tools, heating should not be a problem. The resulting blade was of course very blunt, so after restoring the curve, I had to sharpen it again.
After the restoration I went out again and tested the blade on a few logs, hitting them at full speed. No problems at all. Hard as a nail. I was not ready to 'depart' from this blade and am very happy to be able to keep using it.
Just something I wanted to share,
-Emile
-Emile
